JMB RetrofitsVolks Autos
    Nov 2006
    Cambridge
    90
    Woo noise on BRE engine 2.0 tdi a6
    I have a 2007 A6 with the 2.0tdi BRE engine, just over 116k.
    I have recently noticed a weird woo-ing kind of noise from the engine, almost sounds like the engine is haunted! It only happens when the engine is warmed up. It is most noticeable at low speeds/rpm, but I think that's because there is less ambient noise. The woo starts around 1300rpm and upwards, does the same whether in gear or not.
    There is no noticeable performance loss or smoke from the exhaust, the engine does seem to be using quite a bit of oil and water however - oil light has come on quite a few times. Checked the oil filler for mayonnaise, but it all looks normal. Proabaly using a litre a month or so of oil.
    Any ideas what might be the problem here?
    thanks
    j
    Jun 2011
    Great Melton Norfolk
    1,356
    turbo vanes?
  1. Dry Grinding/abrasive noise on throttle release from A4 TDi Sport 130
    By imported_sguilliard in forum General Technical / How To
    Last Post: 2 Weeks Ago, 16:51
  2. Noise from engine bay of TDI...
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2007, 21:22
  3. Strange noises from the engine
    By tfox in forum Diesel forum
    Last Post: 5th June 2006, 12:14
  4. squealing noise coming from engine
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 09:35
  5. Weird noise when starting engine???
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 11:09
