Results 1 to 7 of 7
Thread: Sat Nav Problem
    Avantageous
    Apr 2010
    Hampshire
    337
    Sat Nav Problem
    Hi guys,
    Just purchased a used Navigation unit to fit to my A6. Bought all the wiring and a GPS attena, all hooked up correctly.
    I downloaded a 2012 map disc, and burnt it to a DVD+R. When I put the disc in, it seems to work fine, until you do a search for a street. It then comes up with loading street names, hangs on there for about 30 seconds, then comes up with 'Check navigation DVD'.
    Does anyone here use a burnt DVD copy of the maps? Had any problems?
    I just want to know whether its the DVD that causes the issue, or if its the drive itself. If its the drive, I can return it for a refund.
    If there is anyone local to me (Aldershot, Hampshire) who has a genuine DVD map (any year), that is willing to let me pop it in my DVD drive and see if it causes the same problem, I would be very grateful.
    Thanks,
    Chris.
    2011 Audi-Sport.net Fantasy Formula 1 Champion
    2005 Audi A6 3.2FSI S-Line Quattro Stratos Blue
    19x9 S6 / Half Leather Interior / Memory Seats / Black Headlining / S6 Paddle Wheel / S6 Exhaust
    Front & Rear Parking Sensors / TPMS / Adaptive Xenons / Actuated Boot Lid / Bose / Sat Nav / Bluetooth / Sunroof
    Double Glazing / Auto Dimming Interior & Exterior Folding Mirrors / Storage Pack / Lighting Pack
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    To keep my original in pristine condition, I use a DVD-R back-up.
    I burned it to a Verbatim -R at 4X - touch wood - it hasn't missed a beat (been using it since Feb/March).
    Rob.
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    Aug 2009
    200
    Quote Originally Posted by ChrisFurlong View Post
    Hi guys,
    Thanks,
    Chris.
    Sat Nav data on DVD from 2011 onwards requires "unlocking" with a pin number (I guess using VCDS) so it is very doubtful that the data you downloaded will work
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Quote Originally Posted by elan2s View Post
    I think that's only the case for MMI 3G. I'm on 2G-High and it's not so picky.
    R
    Aug 2009
    200
    Quote Originally Posted by FactionOne View Post
    R
    Fair point, which I also thought of last night. OP does not say whether he has added a 2G or 3G device, though I presume it is probably 2G as most later cars that could accept 3G had it installed at the factory so less demand for retrofit
    1970 Lotus Elan +2S
    Avantageous
    Apr 2010
    Hampshire
    337
    Thanks for the replies guys.
    Yes I have 2G.
    Ill try burning the maps to a DVD-R today and see if that makes a difference.
    Avantageous
    Apr 2010
    Hampshire
    337
    Burnt the maps to a DVD-R this morning, popped it in and it seems promising.
    When you choose the Street Name option, it comes up with loading and loads them in about a second, whilst on the old DVD it would hang for 30 seconds and then come up with 'Check navigation DVD'.
    Ill go for a drive later on and see how it goes.
  1. RNS-E & MMI SAT NAV PROBLEM
    By archiemac281 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd June 2012, 19:00
  2. sat nav problems
    By DAF1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd March 2011, 16:42
  3. S4 Sat Nav Problems
    By boulevard in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2010, 19:45
  4. A4 Sat Nav problem?
    By the schmall fella in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 29th May 2009, 10:03
  5. Sat Nav problems
    By trekbiker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2007, 11:29
