Sat Nav Problem
ChrisFurlong
Avantageous
Hampshire
Hi guys,
Just purchased a used Navigation unit to fit to my A6. Bought all the wiring and a GPS attena, all hooked up correctly.
I downloaded a 2012 map disc, and burnt it to a DVD+R. When I put the disc in, it seems to work fine, until you do a search for a street. It then comes up with loading street names, hangs on there for about 30 seconds, then comes up with 'Check navigation DVD'.
Does anyone here use a burnt DVD copy of the maps? Had any problems?
I just want to know whether its the DVD that causes the issue, or if its the drive itself. If its the drive, I can return it for a refund.
If there is anyone local to me (Aldershot, Hampshire) who has a genuine DVD map (any year), that is willing to let me pop it in my DVD drive and see if it causes the same problem, I would be very grateful.
Thanks,
Chris.
To keep my original in pristine condition, I use a DVD-R back-up.
I burned it to a Verbatim -R at 4X - touch wood - it hasn't missed a beat (been using it since Feb/March).
Rob.
Hi guys,
Thanks,
Chris.
Sat Nav data on DVD from 2011 onwards requires "unlocking" with a pin number (I guess using VCDS) so it is very doubtful that the data you downloaded will work
I think that's only the case for MMI 3G. I'm on 2G-High and it's not so picky.
R
R
Fair point, which I also thought of last night. OP does not say whether he has added a 2G or 3G device, though I presume it is probably 2G as most later cars that could accept 3G had it installed at the factory so less demand for retrofit
Thanks for the replies guys.
Yes I have 2G.
Ill try burning the maps to a DVD-R today and see if that makes a difference.
Burnt the maps to a DVD-R this morning, popped it in and it seems promising.
When you choose the Street Name option, it comes up with loading and loads them in about a second, whilst on the old DVD it would hang for 30 seconds and then come up with 'Check navigation DVD'.
Ill go for a drive later on and see how it goes.
14K
15
2K
920
11
17K
