Volks AutosChris Nott
    Aug 2012
    Bedfordshire
    HELP! 2010 A6 Changing lights beam for driving in Europe ( can't be done Via MMI)
    First of all big thank you to all of you for free refreshments at AITP yesterday!
    (2010 A6 Le Mans with Xenon headlights)
    I hope you can help me out with this. My sister starts Uni in Holland next week so we are taking her down in the A6 but the problem that have is we don't know how to change the lights for driving in Europe. Tried using the MMI but had no luck. Can you help?
    Avantageous
    Apr 2010
    Hampshire
    337
    Not sure, but there should be a flap on top of the lights that will it off the beam and stop it from pointing left. I can check on mine tomorrow. Failing that, deam deflectors are your friends
    2011 Audi-Sport.net Fantasy Formula 1 Champion
    2005 Audi A6 3.2FSI S-Line Quattro Stratos Blue
    19x9 S6 / Half Leather Interior / Memory Seats / Black Headlining / S6 Paddle Wheel / S6 Exhaust
    Front & Rear Parking Sensors / TPMS / Adaptive Xenons / Actuated Boot Lid / Bose / Sat Nav / Bluetooth / Sunroof
    Double Glazing / Auto Dimming Interior & Exterior Folding Mirrors / Storage Pack / Lighting Pack
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    AFAIK you need VCDS to do a code change...
    'Normal' Xenons, Select Control Module - 55 Xenon Range - 10 Adaptation and then use the up arrow to go to and change Channel 10 from 0 to 1. Click Save to store the new value.
    or
    'Adaptive' Xenons, Select Control Module - 55 Xenon Range - 10 Adaptation and then use the up arrow to got to and change Channel 23 from 0 to 1. Click Save to store the new value.
    Not done this noted for my own use from others post/threads... an error is displayed on DIS when done this is normal and will correct once coded back to std settings ie uk mode...
    As your's is face lift maybe "Long coding helper" or a guide box may appear...
    Jun 2007
    40
    I have a 2010 model A6 with Adaptive Xenons. I asked the dealer about changing over the headlight aim. On some models it is possible and mine is one of them. It is done using the dealer computer or VCDS. My Audi dealer quoted me about £10 to do it. My old 2006 model A6 with Xenons could not be done and I have to use beam deflectors. Luckily I had some Headlamps protectors so I was able to fit the beam deflectors to these. There are hard to clean the glue off afterwards. Be careful when removing the beam deflectors as the Headlights are plastic and can easily be damaged.
    My mates 2010 model A4 with Xenons can be done via the MMI.
    Hope this helps
    Pete
    hazey7's Avatar
    Sep 2009
    170
    Too True.... anyone know how best to remove the glue that those beam deflectors leave behind?
    27,121
    Just note though it merely lowers the beam pattern, doesnt change it to other side & it should be possible with vcds in 55 as stated with xenons of most oem type.
  1. Swing lights for driving in Europe
    By Lapchien66 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2010, 22:42
  2. Adjusting Adaptive Xenon headings for driving in Europe
    By h5djr in forum VCDS (formerly VAG-COM) forum
    Last Post: 6th December 2009, 17:01
  3. How to change first beam lights?
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2005, 21:03
  4. Changed Stop light bulbs for LED's
    By imported_ChristianF in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2005, 18:39
  5. Help switching lights for driving on right
    By A4drive in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2004, 14:34
