AH FabricationsChris Nott
Results 1 to 15 of 15
    Jul 2012
    Rotherham
    Tyre pressures on 19's
    Hi guys, just had 19's fitted to my 2007 A6, 2.0 TDI SE, tyre sizes are 235/35 x 19, the dealer set them to 34 psi all round as a default setting, just seems a little bit floaty, any recommendations greatly welcomed.
    Apr 2012
    Oxford
    126
    I have a 3.0 TDI on 255/35/19, and I tend to run mine high (44 front, 38-40 rear) for better economy, plus I prefer the sharper/lighter steering feel it gives. You could prolly get away with less at the front, due to the lighter engine.
    In any case, the recommended pressures should be on a sticker on the fuel filler flap
    Apr 2012
    N. Wales, LL22
    1,224
    yep, photo of filler cap sticker needed
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Jan 2009
    I have a 2.7V6 Quattro avant on 19"s and the recommended pressures are 42 on the front and 38 psi on the back. It's more on the front due to the weight of he engine.
    Suprised fishy fish runs more, but might try those pressure myself to see if it makes a difference to handling or mpg.
    chers
    May 2012
    Kings Lynn
    903
    My Avant is 2005 2.0L and I have 19s and ruhn them all at 34 all round... is this stupid pressures?? :S
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    warren_S5's Avatar
    Oct 2007
    7,164
    I think there is an element of personal preference in what pressures you choose to run. I run my 235/35/19's at 38PSI front and 34PSI (S3, not A4), and although the manufacturer recommendation is higher I just find the ride quality is a just too jarring at recommended pressures (42/38). If we put luggage / weight in the car we always adjust up, but the biggest issue other than economy is that you could suffer from uneven tyre wear if you have a massive difference over OEM spec. I'd be inclined to ramp it up a few PSI, anywhere within about 10%+/- shouldn't be out of the question.
    hazey7's Avatar
    Sep 2009
    170
    From personal experience, my 255/35/19s have to kept at the makers recommended pressures, 44/38, otherwise they will not wear correctly.
    You soon get used to the bone-jarring, wince-inducing, spine-smashing, noisy unforgiving ride.
    Jan 2011
    According to the sticker in the filler cap my 255/35/19s should be at 44 Front and 38 Rear when car is lightly loaded (3 persons with no luggage). When the car has more than this the sticker shows that they should be 45 Front and 48 Rear. The manual recommends keeping the tyres at the higher value if you don't want to keep changing the pressures with loads, so I've decided to keep all 4 of my tyres at 48 psi. They were all at 39 psi when I bought the car 2 weeks ago and all 4 tyres showed signs of more wear on the outer shoulder, so the higher pressures I now use should correct this and allow them to wear more evenly across the whole tread width. At 250 quid per tyre I want them to last! The ride isnt too harsh, not as bad as my wife's S3 anyway.
    Jan 2012
    1,837
    On the C6 the 19's should have 255 tyres fitted.
    sined's Avatar
    Aug 2012
    Lower profile tyres run higher pressure to help avoid damage to the rim.
    Jul 2012
    Rotherham
    Update, have changed the tyres to 255/35's and running them at 38psi front and rear, putting the correct size ratio tyres has made a big difference, 235/35's are just too low a profile. Much more settled a ride now, thanks for all the replies as well.
    hazey7's Avatar
    Sep 2009
    170
    No Mr Bond, I expect you to etc etc etc,
    You should run the fronts at 44 otherwise they will not wear properly......
    Avantageous
    Apr 2010
    Hampshire
    337
    Any ideas what I should run my S6 wheels at? Think there 265/35/19 tyres.
    2011 Audi-Sport.net Fantasy Formula 1 Champion
    2005 Audi A6 3.2FSI S-Line Quattro Stratos Blue
    19x9 S6 / Half Leather Interior / Memory Seats / Black Headlining / S6 Paddle Wheel / S6 Exhaust
    Front & Rear Parking Sensors / TPMS / Adaptive Xenons / Actuated Boot Lid / Bose / Sat Nav / Bluetooth / Sunroof
    Double Glazing / Auto Dimming Interior & Exterior Folding Mirrors / Storage Pack / Lighting Pack
    Jan 2012
    1,837
    They'll be inside your fuel filler flap
    Greeny233's Avatar
    Mar 2011
    Llangollen
    689
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    Tyre pressure should be kept the same. Same pressure just a different volume of air. 19's will feel more harsh as they a lower profile and stiffer side wall.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
  1. A3 3.2 tyre pressures
    By GARTHY in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 11:04
  2. tyre pressures
    By carl310166 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 15:46
  3. Tyre pressures
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2004, 08:39
  4. TYRE PRESSURES
    By wezhaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 08:06
  5. Optimum Tyre pressures
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2003, 13:37
