EM TuningChris Nott
    Jan 2011
    14
    3.0 tdi Injector Problem
    Toying with the idea of buying a second hand A6 3.0tdi, was there a certain year of manufacture where the injector problem was perceived as being resolved?
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    My car an A6 Avant 3.0 TDi Quattro 55 plate 2005 had 70k on clock when bought it in Aug11 now 77k@time of post... it has chain rattle which is a early model issue... a £2k fix@indi garage... as engine+transmission removed to get at chains at rear of engine if you want to get all done... some people advise you can get done one top tensioner which follows Audi TPI 2012744/6...
    Before I decided to get work done I tried to investigate the state of my car i) visually ii) with VCDS MVB's to see if car warrant keeping and work done to it or just p/x or sell and get another...
    If budget allow I would go as close as 09 onwards as they have most if not all production issues cured by that time from things I've read and studied... plus facelifted and you may end up with MMI 3G HDD vs MMI 2G variant on a pre facelift..
    Currently my injectors are 059 130 277 S, must be orig
    059 130 277 S
    059 130 277 Q DROPPED 01/06/2005
    059 130 277 AA DROPPED 01/06/2006
    059 130 277 AB DROPPED 01/09/2006
    059 130 277 AH DROPPED 01/04/2009
    059 130 277 BD Current part since 09 (these apply to BMK BNG ASB engine codes)
    I have no issues with my injectors been i) advised on another forum which I frequent ii) the garage which doing work for chain tensioner have also come to this conclusion...
    as an owner this is all the advise I can give... but again each car used or new can have it's very own different issues...
    so by all means only use my experience as info not the norm...
  1. Anyone else with this problem on 2006 2.0 TDi? Injectors...
    By jfarhead in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th December 2013, 10:14
  2. car wobbles on idle TDI(possible injector problem!?)
    By MAD_Adamski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2012, 09:27
  3. tdi injector duty problem
    By nokia_aid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2011, 19:57
  4. no1 injector problem on 1.9 tdi
    By tp7n in forum Diesel forum
    Last Post: 31st July 2005, 10:47
  5. A3 2.0 TDI Starting problems
    By imported_simey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2005, 20:18
