JMB RetrofitsAH Fabrications
Results 1 to 14 of 14
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    C6 A6 Lemans 3.0tdi fault.
    Hi after any ideas from people.Was cruising along the motorway the other day with cruise on when my glow plug light started flashing then my engine management light came on and the glow plug light went off.when sat idling the car is now hunting slightly, and there are two valves going to and fro hard to explain.These are not the swirl flaps as these are fine have checked them out.both valves are near the turbo and if i disconnect one of them the glow plug light comes on.but i think the valve located in the inlet but after the turbo intercooler side is making a buzzing.its getting scanned tomorrow but was just seeing if anyone had a heads up
    V8 baby... oh yeah
    Jan 2012
    1,837
    Fault code scan is a definite must
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    Car was scanned and reset today i will post the codes later as some were from me disconnecting items to try to diagnose.Light was reset but has since come on again and as soon as i can get my phone to connect so i can upload the video i will post it.
    V8 baby... oh yeah
    Jan 2012
    1,837
    Doesnt sound good whatever that is - post the scan and we can decode them from Rosstech using the codes.
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    will be getting re scanned later in week as light is on but delving deeper whatever the issue is its causing the turbo air vein adjuster (vgt) to be adjusting the veins from one end to the other?????? coaked turbo did come on when cruising on the motorway and i do a lot of town and short runs? and the other part looks like the egr valve being opened and closed. oh and i need some glow plugs lol.
    V8 baby... oh yeah
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    Results from first scan.Glow Plug Cy 5, Cy 3...... not an issue will sort before winter as knew at least one was weak as has been lumpy starting now and then.R06B Throttle Valve stuck or difficult to move. (p106b????)P1580 Throttle actuator Bank 1..... (swirl flap valves?????)Exhaust Gas Recirc Cooling Valve Open circuit P2425 (p2452???)Control Circuit for Turbo Charger Electrics malfunction P3348im thinking that the throttle valve is throwing the fault and the turbo veins and the egr are being cycled to try to compensate? but any ideas welcome.
    V8 baby... oh yeah
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Sorry to digress and go off topic...
    Will try to root around for your fault codes...
    Just noticed in sig, you have a remap .... may I ask where you had done? how long you had? how's your experience been with it?
    Thanks in advance...
    Sorry to be pain..
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    it is an angel tuning remap done of a group buy on here had it year and a half maybe more and fantastic...
    V8 baby... oh yeah
    gupsterg's Avatar
    Jun 2012
    279
    Hi Gavin...
    Thanks for info on your remap
    I not mech/tech just an estate owner...
    Like doing forum thing as to learn more about issues which could occur on my car and fixes...
    but whilst looking around found this which may identify parts/functions of turbo VTG...
    google ssp 325 check pages 15 has turbo stuff... page 16 EGR stuff...
    sorry for my newbie answer ... if find more info will post...
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    think i have found the problem...
    the throttle body part number A2C53085614 or 059145950A has stripped the plastic cogs so the valve is stuck open.
    prices please from anyone that can...... id rather buy new as it would be a lucky dip with used plastic parts.
    V8 baby... oh yeah
    gupsterg's Avatar
    Jun 2012
    279
    rev history of 059 145 950 A >> 059 145 950 D >> 059 145 950 H >> 059 145 950 R ....
    again only going by the part number supplied in your post...
    new @ dealer list price approx £331...
    gupsterg's Avatar
    Jun 2012
    279
    Hi Gavin0478
    I was wondering if I can pick your brains...
    My car is a 2005 55 plate 80k on clock... I am getting theses erratic idle revs on start up... I am suspecting my throttle valve body maybe issue... below is VCDS log...
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0040
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 02334 785 00200
    VCID: 254BDA7FECF6CC30723
    1 Fault Found:
    17953 - Throttle Valve Controller
    P1545 - 002 - Malfunction - Intermittent
    Freeze Frame:
    RPM: 1134 /min
    Torque: 7.8 Nm
    Speed: 40.3 km/h
    Voltage: 13.91 V
    Duty Cycle: 93.9 %
    Bin. Bits: 001
    Mass Air / Rev.: 499.4 mg/str
    Voltage: 0.000 V
    Readiness: 0 0 0 0 0
    Ross Tech explanation Link:- 17953/P1545/005445 - Ross-Tech Wiki
    I've cleared this fault and it has not come back yet.... I have no other faults codes occurring ...
    I have check measuring block 18 on [01] Engine module in VCDS... again reactions seem correct on throttle...
    This is video of it occurring sometimes deviation of revs is higher... as my car is early one I really suspect the throttle... I have had engine cover off when this is occurring and none of the parts which were moving on your video are happening...
    When I was googling around for my issue I found this thread Link:- Audi A6 3.0 tdi hunting revs
    So another is having issue like mine but no one yet advise on fix... my first year with car been turbulent I really thought I was picking up a cracking car... now spent £4k on it in first year... and this issue makes me feel
    Before break down of your throttle body were you getting erratic idle revs?
    Thanks in advance for any insight
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    what have you spent so much on!!!!!!
    on mine when it was ticking over you could hear a click and a buzz because it was trying to use the egr/vnt to idle better.
    it is only 20 mins to take the butterfly out and check if the cogs are knackered but does seem similar...
    V8 baby... oh yeah
    gupsterg's Avatar
    Jun 2012
    279
    My egr/vnt is not at all compensating on mine, they do not shown any movement...
    When it occurs it carries on until you give it some revs, then cease... like posting on piston heads...
    £2k was chain rattle fix Link:- My post
    £500 was home servicing ie oil/oil,fuel,air,pollen filters, all discs and pads done by me Link:- Fronts Rears
    £500 was retrofits done by me Links: AMI DAB Graphical PDC Mirror tilt
    £500 at dealer for front C links, rear gearbox output seal ( I was not knowledgeable about my car at time)
    £500 on other bits like VCDS, mats, cleaning products, little trim fixes, parking sensors,etc
    I've had rear wiper pipework split under carpet in three places Link: 1st issue 2nd issue ... luckily bluetooth module did not go was virtually swimming in water...
    I've taken apart rear wiper motor twice once leaking water internally, second time arm seize Link:- my thread
    After chain rattle fixed I had some issues from the work garage did to sort Link 1 Link 2 there was also a little trim issue where they folded seat down after place stuff in footwell so when got car back had nice crease in my clean leather head rests... garage was very unhelpful aftercare
    I'm just waiting for the car to blow up next when going down the motorway...
    So you were getting fluttering revs? More specifically before proper breakdown what symptoms?
  1. NEWBIE....'03 a3 2.0tdi facelift, various faults - any help appreciated
    By A3Danny in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th June 2012, 23:38
  2. Audi finally acknowledge 2.0tdi 170 injector fault?
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd February 2012, 19:05
  3. A3 2.0tdi BKD Fault codes :(
    By j50sho in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th July 2010, 15:06
  4. 2.0tdi egr valve fault and less MPG!
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2010, 13:55
  5. Lemans Motorsport Dumpvalve
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2003, 20:24
