Chris NottBadger5
    Jul 2011
    41
    C6 3.0 TDi Quattro Parking Brake
    All
    Had an issue with the EPB not releasing a while ago, and have been living without it by leaving in Park, and had no further problems.
    Until today, that is. PArked up at home this evening, left in Park, ignition off, out came the key, and a strange noise from the rear wheels.
    It sounds like the parking brake valveor solenoid (is there one?) trying to motor over, but failing. The "motoring over" sound keeps going, even though the key is out.
    I cure it by key in again, and applying the parking brake. Key out and the noise then disappears.
    The noise seems to come from centrally by the back wheels, rather than just one or the other.
    Any ideas? Thanks in advance?
    Jul 2011
    41
    What I forgot to mention was there is no warning message on the dash.
    Also, the parking brake switch light illuminates when the switch is pulled up, but when returned back to its normal position, with the actual EPB on, it is not illuminated.
    Strange!
  1. Rear brake upgrade b5 a4 2.5 tdi quattro
    By adamss24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2009, 11:55
  2. TDI quattro brakes - disc and pad upgrade
    By TDI_Boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 21:50
  3. 2.5 TDi Quattro hopeful speculation?
    By bsharp in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 13:01
  4. Turbo noise - 1997 1.9 Tdi Quattro
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2003, 15:36
  5. 1997 A4 1.9 Tdi Quattro - turbo noise
    By Holywood in forum The Welcome Section
    Last Post: 26th August 2003, 15:10
