EM TuningAH Fabrications
Results 1 to 7 of 7
    InnerGuard's Avatar
    Jun 2012
    Leicester
    14
    Car revving at idle
    Hi, my 07 plate A6 2.0L TDI S Line has started rocking and revving at idle. This happens in drive, park and neutral, is intermittent and has only started happening since its last service and cam belt change.
    Have taken it back to the garage 4 times now. Each time they say it's nothing that they've done and so the problem remains. I've changed fuel filter, the cam timing is supposedly ok.. So I'm stuck!
    Any ideas or advice greatly appreciated! Thanks!
    May 2012
    Norfolk
    118
    If the car was fine before the service and you got it back doing that the fault lays with them take it back and get them to resolve the issue.
    InnerGuard's Avatar
    Jun 2012
    Leicester
    14
    They're being pretty good about it but just not getting to the bottom of it, and are now saying they've ran out of ideas! :/
    Jan 2012
    teeside
    45
    I had a similar problem with my 2000 a6 2.5 tdi. The car would tickover erraticllyie one minute nuicely at 800 then
    Upto 1200. I found that replacing the temp sensor sorted this straight away. This cost me under £6 for the part. To fit it was just q clip of remove sender replace clip on . The temp sensor has four prongs. Two for temp sensor two for engine ecu.
    InnerGuard's Avatar
    Jun 2012
    Leicester
    14
    Thanks Abdul! I've got it in the garage (again!) on Thursday I'll mention this!
    Jan 2012
    teeside
    45
    Did u sort it?
    InnerGuard's Avatar
    Jun 2012
    Leicester
    14
    Quote Originally Posted by abdul h ghafoor View Post
    Did u sort it?
    I've actually part ex'd the car now but touch wood it was ok before I sold it!
  1. Revving on Idle
    By LucasS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st July 2013, 12:12
  2. car wobbles on idle TDI(possible injector problem!?)
    By MAD_Adamski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2012, 09:27
  3. vibration when car is idle??
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2009, 06:44
  4. Whilst Idle - the car jerks/revs rise a little
    By GibletsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2007, 19:12
  5. Car shaking when idling
    By Burt25 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2006, 10:39
