Monster MotorsportEM Tuning
    May 2012
    Side Light Bulb replacement
    Hi
    A6 Avant 57 2.0 Tdi S-Line
    I'm struggling to find the easiest way to replace the drivers-side side-lamp bulb. Filter hose is in the way. Take the filter off/out and still can't get at the back of the lights to replace the bulb. Halfords bloke admitted defeat tonight saying I'd have to take it to a garage. Another forum I've read says that the bumper has to come off !!
    Anyone any ideas
    Jon
    Gavin0478's Avatar
    May 2010
    cleveland
    452
    there is a cover in the wheel arch to remove for access i do believe from memory
    V8 baby... oh yeah
    May 2012
    If anyone's interested, I had the bulb changed at Audi and they charged me £14.65 !!
    Jan 2012
    teeside
    45
    U have to remove the inner cover from the wheel arch of, it about 10 allen screws and couple of bolts. 5 min job
    Oct 2012
    Yatton
    156
    What pain in the arse job I've removed to rear cover from the light unit still no joy I only want to replace my normal sidelight bulb with and LED
    Oct 2012
    Yatton
    156
    Right worked it out & taken some pics I'll do a proper write up soon but you dont go through wheel arch for main dip & side lights only for indicator bulb & then all you do is prise off a small u plastic cover
  1. Side light bulb replacement.
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2012, 18:04
  2. Reg plate light.. bulb replacement?? 2003 Avant
    By imported_larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2006, 13:49
  3. how to remove side light bulbs?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 13:04
  4. fog light bulb replacement?
    By imported_RELOADED99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2004, 21:24
  5. New A3 Side Light Bulb Change
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2004, 21:01
