Thread: Bluetooth
    Dec 2011
    12
    Red face Bluetooth
    Hello All
    Can you connect a phone via bluetooth without the gizmo in the armrest mine didn't have one when i bought it,my car is a 2008 avant S line tdi any help would be very welcome.
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Search on your phones bluetooth to see if you car has bluetooth to begin with.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    Aug 2009
    200
    I believe that on the C6 A6s the only way to get Bluetooth (factory fit) was to have either the Low or High Telephone option. Both gave you fittings in the driver's arm rest. Therefore if you have no contact panel showing in the arm rest then it is very unlikely you have Bluetooth fitted. There are some aftermarket options available that will integrate Bluetooth with the MMI system or you can go for a standalone option such as one from Parrott.
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    Aug 2005
    UK
    16
    Hello,
    There are a couple of Mobile Phone connectivity options available on the C6 A6......
    The GSM factory fit comes with the front arm rest connections and Bluetooth. However, there is also a bluetooth factory fit which was only available with MMI High and does not have any front armrest connections unless the optional wired privacy handset was spec'ed with the car.
    (Data taken from October '07 A6 Sales Brochure....)
    Dec 2011
    12
    Thanks everyone i didn't know, but it had bluetooth fitted when i paired my phone up it came on the display in the dash and it all works
  1. Bluetooth help!
    By Scotty_J in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2011, 09:33
  2. Bluetooth
    By J7-AUDIA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2008, 11:29
  3. Bluetooth??????
    By jay07 in forum In-Car Entertainment
    Last Post: 18th December 2007, 19:47
  4. Bluetooth again (A3)
    By Marcyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2007, 07:54
  5. Bluetooth in my A4
    By Maraby in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2007, 07:49
