EM TuningAH Fabrications
Results 1 to 14 of 14
Thread: Changing bulbs
    Rikster23's Avatar
    On the facelift path...
    Dec 2007
    London
    243
    Changing bulbs
    I was wondering who has changed their headlight bulbs and interior lighting?
    Reason I am asking is I was told that if I get the wrong bulbs for the front headlight it might cause issues with the ecu?
    Is this true?
    I am hoping to change my door sill, interior and boot lights with the newer LED type ones.
    Can anyone advise?
    Rikster23's Avatar
    Dec 2007
    London
    243
    Bump - Anyone know info on this?
    Aug 2009
    199
    Not sure it will affect the ECU but with LEDs you may get a "blown bulb" warning as the resistance is lower. I believe some replacement LED bulbs have a resistor fitted to address this issue.
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Crocus or Daffodil ?
    Jan 2012
    Chester le Street
    44
    I fitted LED stop/tails in my Allroad and the blown bulb warning was activated......EVERYTIME I pressed the darned brake pedal!!! lol
    Rikster23's Avatar
    Dec 2007
    London
    243
    So surely there are idael replacements for the bulbs?
    I am after the standard front lights and the fogs to replace as I would prefer a cool white look as opposed to the yellowish light the standard A6 gets.
    Advice welcome.
    Aug 2009
    199
    Quote Originally Posted by Rikster23 View Post
    Advice welcome.
    If you stick with H1/H7/H11 bulbs for Main/Dipped/Fog then you should have no problem. There are a large number of options giving Xenon effect, White and Blue White and extra light, so it will be a case of paying your money and making your choice (try a website like AUDI A6 / A6 AVANT (2005 - 2008) Car Headlight Bulbs | PowerBulbs. Suggest you steer clear of Xenon replacements (as opposed to Xenon effect) as they may result in an MOT failure as cars with Xenon bulbs are required to have automatic leveling and headlight washers to reduce the risk of dazzle. Also remember if you go above the standard wattage then you may need to change the fuses (technically also illegal)
    1970 Lotus Elan +2S
    Rikster23's Avatar
    Dec 2007
    London
    243
    Thanks for that info. Its useful website. I wont be upgrading my lights to xenons as you said they need to have auto levelling.
    TwistedMind's Avatar
    Long Live The A6
    Jan 2011
    115
    I have swapped to LED's with no problems, Just get the Canbus rated ones.
    Audi A6 1.9TDI 2000
    Love the problems !
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Look for can bus ones or error free ones also have a chat (pm) with t8ups (forum member) he should sort you out
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    Rikster23's Avatar
    Dec 2007
    London
    243
    Is there a place you would suggest to purchase these? This would help greatly. Thanks in advance.
    Jun 2011
    Wellingborough
    1,157
    I can help with these?
    i am a forum sponsor sell upgraded lighting.
    What are you after?
    i also have a C6 so it shouldnt be hard knowing what you require.
    Trups
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Mar 2011
    6
    H Guys
    i am replacing the day running bulbs in mi Xenon headlights ( this are the older ones where there is a single bulb that uses one the same style as a indicator / rear light bulb problem is I can only just get my hand in there and don't know how these bulbs come out do they pull out or pull and twist ....any help greatly received
    Furion's Avatar
    Oct 2012
    Is this true?
    Can anyone advise?
    Take a look at this thread, i asked the same question.
    Led equivalents to convential sideight bulbs ?
  1. Changing bulbs...
    By David in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd July 2012, 15:09
  2. Changing Bulbs
    By grumbas in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2008, 16:20
  3. Changing bulbs
    By Vertigo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2007, 20:01
  4. changing bulbs?
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 10:51
  5. changing my bulbs
    By thumper in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th October 2005, 21:40
