Chris NottAH Fabrications
    Feb 2007
    Aberdeen
    Exclamation 3.2 Engine Misfire
    Hi, Can anyone help explain a random misfire.
    I have a 2004 (54) plate A6 3.2 Quattro with 77k on the clock. It starts from cold fine and when the engine is hot it will start fine, but if it is left to cool for 10 minutes it will misfire. The cowboys that I bought it from claim it is a characteristic of the engine and Audi think it may be stretched timing chains but could not explain why it only happens on a warm engine. They also want £4k to see if changing the chains will fix it.
    There is no loss of power and no lights on the dash. Apart from this it runs perfect.
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Have you had your coil packs replaced under the recall via Audi.
    As far as I'm led to believe a misfire could be caused by a faulty/failing coil pack.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Feb 2007
    Aberdeen
    Coil packs have not been replaced. I was told my car was not covered by the recall. I will look at the coil packs though. Thanks.
  1. Engine Misfire - Can't access spark plugs
    By silverswish in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2011, 14:19
  2. Engine Management Light and Misfire - 2004 1.8T
    By dalespitfire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2010, 12:48
  3. TDi hesitant/ misfire engine problems
    By DSan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2010, 01:50
  4. Misfire please help :( (no engine light, no codes on VAG)
    By abc123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2009, 09:56
  5. Help!! - In dire need of advice... engine misfire
    By Raspeir in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2007, 14:21
Tags for this Thread
