EM TuningJMB Retrofits
    Feb 2012
    2006 2.0 tdi worth buying or walk away
    Hi guys
    New here and looking at buying a 2006 a6 2.0tdi with 46000 miles £10,000 is it worth buying or should I leave it alone due to the oil pump problems. It has full Audi service history and is being sold by a local Vauxhall dealer.How big a problem is the oil pump failure does it affect all cars or is it just an unfortunate few.
    Any advise on this would be greatly appreciated as the more I look into it the more I get confused.
    Simon
    North East
    607
    Quote Originally Posted by Simon Tate View Post
    Hi guys
    Simon
    Read the sticky on the B7 A4 forum and check the engine code before you make a decision.
    Its a case of you pays your money and you takes your pick.
    Sorry I can't be more specific without writing several paragraphs and its bed time here, Zzzzzzzzzzzzzzzzz
    Jan 2012
    Chester le Street
    44
    The way that I see it, every car has their common problems, the fact that you're aware of the possibilty of something going wrong speaks volumes about how interested you are in the car. Why not buy it and do the oil pump anyway......if a pump has lasted almost 6yrs so far, is it not reasonable to suppose that a new pump will also last this long, also, you will probably be thinking of selling the car within the next 6 yrs anyway so it would offer you 5 or so years reassurance to get it done as a matter of course, along with the timing belt, servicing etc etc. It might cost you an extra few hundred quid upfront, but I find that spending the money on preventative measures is often more economical than spendin money on repairs after something has gone wrong!
    Aug 2010
    1,540
    reguarding balance shaft problems. if its one of the effected engine codes and theres nothing in the history to say its been changed.... i wouldnt touch it!
  1. how much is a 1.6 petrol a3 worth? 2006
    By xyz1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th November 2011, 20:34
  2. Buying Advice: 2006 A4 1.8T Quattro
    By Mr1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th November 2010, 12:10
  3. Is this worth buying?
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2009, 16:06
  4. Are these discs and pads worth buying??
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 20:24
