Badger5JMB Retrofits
Thread: Remapped???
    May 2010
    Remapped???
    This is a quick one: Is there an easy way of checking if a vehicle has been remapped??
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Nope, not really different mapping companies use different software to re-flash the eeprom, only a proper mapper with the correct equiptment could check the software on the eeprom
    york
    50
    You could have a look at the ecu case if thats been unsealed (opened) its properly been remapped
    Fraser's Avatar
    Aug 2003
    the north
    586
    run some logs with vagcom
    3rd gear pull and look at the MAF readings
