Volks AutosEM Tuning
    Feb 2009
    7
    Cool Audi Allroad problems
    Hello guys, any help on a few issues would be much appreciated. I recently bought a 2.7t allroad from 2000. I have had a few problems with it so far:
    -rear left hand bulb blue after being recently replaced
    -hazards starting jamming on some times and now have stopped doing that
    - The dash board is saying all four doors are open and the windows have stopped operating
    Any help or advice would be much appreciated
    Watty's Avatar
    ..... (_!_) Sarah's A3s #1 Fan
    Railway Line Champion
    Sep 2007
    Perth, Western Australia
    406
    Sounds like the 'comfort' (i think that's what it's called) module. Controls locks and windows. try doing a search on here which might throw something up.....
    Sometimes bulbs do blow, but if it blew more than twice stright away, I would check the fuse rating to see if it's correct?
    Audi A6 Avant (2002) 2.5 V6 Quattro. Sunroof, Bluetooth mp3 Xcarlink, 6cd, xenons, tints, ST3, 18" RS6s
    I have VCDS and I'm not afraid to use it, well, a little bit?
    Feb 2009
    7
    After doing some research and lifting the carpet in the passenger side footwell, I found the comfort ecu that controls the central locking. I removed it from its casing and found there was a lot of water in it. I took the ecu casing off, disconnectted the plugs and found that one of the terminals had corroded so badly I had to re solder it....
