AH FabricationsVolks Autos
    Sep 2004
    London
    High pitched noise when starting from cold
    Hi all,
    When starting my A6 2.7T from cold it produces a constant pitched noise for about a minute or so and sounds quite nice. I assumed it was something to do with the turbos or something warming up. I recently (about a week ago) started the engine and got the same noise but a hell of lot higher in pitch. Again it went away after a minute or so. It has not happened since.
    Does any one know what this noise is?
    Regards
    ajek.
    Apr 2003
    s.wales
    363
    Re: High pitched noise when starting from cold
    Hi mate,had a similar sounding problem with an S3 a year or so ago. It was the auxillary air fan or the air con fan I believe. High pitched and lasted for a minute or so. Qiute expensive too if not covered on the warranty. Hope this helps.
    Regards, s3bow.
    Sep 2004
    London
    Thanks for the reply. Don't get get time to log on much but thanks.
