Thread: Vagtacho 2.5
    griswold's Avatar
    336
    Vagtacho 2.5
    Anybody used vag tacho on their A6?
    need to get pin code to code new key for my 02 A6?
    connecting to ecu but read pin button greyed out program key is ok.
    Had this when i first tried on my A4 but by selecting vdo old all functions then worked.
    This doesn't work with the A6
    shows
    try to connect kombiinstrument at 10400 bps
    ok
    4B0920981K kombi+wegfahrs. VDO D11
    OK
    ok
    disconnected.
    So i can connect but cant get all options?
    maybe more tries?
    Dec 2009
    14
    Sorry to depress you further, but I couldn't get it to work on my Allroad either..
    Using "Connect any Instrument" it detected VDO D11...unfortunately VDO D11 is not listed in the Instrument List, so I'm stuck.
    Like you , I'm only trying to get the code to programme a spare key.....
    Fox
    Oct 2007
    41
    Worked fine on my 2.7t. Read pin and programmed my spare key....
    Perhaps try the latest version, 2.5 is quite a few years old now.
    Fox
    Oct 2007
    41
    griswold's Avatar
    336
    i was using 2.5 anything newer and will wipe the cable as i found out but was able to flash it getting vag commander to try otherwise its off to audi
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
