Badger5Volks Autos
    Mar 2010
    9
    convenience control module
    Audi A6 Avant 2.5TDI SE 2003.
    Yep i have had that flood in the back passenger footwell. Fair bit of stuff about it on the forums and a few good tips. Carpet cut, bucket of water removed, sponge sound proof squeezed (another bucket), cleared drain plugs under battery, ( nearly strained me back on that, battery is a ton weight). Now i need to locate the convenience control module. Will i need to remove front passenger seat for this? Is it a straight forward unplug and plug back in? Also how do i dry it out? If its buggered is it a straight replacement part? Just wanna make sure my next steps are the right ones. I was sweating over cutting the carpet, knowing a mass of wires were under there. Any help would be most welcomed
    Thanks in anticipation of whoever points me in the way of the light. Phil
    Mar 2010
    9
    Car is nice and dry now. Still indicators are stuck on and the rad/cd/nav keeps wanting me to eneter code and now won't com to the dash. Sure its to do with the CCM. Just need to know where its located and how to get to it. Is it under the front passenger Seat? Rear or back of seat area? Please help am due an Mot in a few days gotta get indicators sorted. Many thanks Phil
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    Under the passenger seat, along with the BT module
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    Mar 2010
    9
    Well ave found it. Thought i would have to remove seat but upon lifting the front carpet there i was in the floor pan, (sat i a puddle). Cleared water out and removed the CCM. Lucky the water had'nt got into the electronics. Not so lucky, one of the plugs to the box. 2 wires had come out due to corrosion. One was for the indicator reasons why they were flashing madly and one for the courtesy light this to was flashing like a disco light. I managed a botch temp repair but i will have to replace the plug. Just hopin that audi will give me just the plug and not say i have to buy a whole wiring loom. Also the sat nav radio is playing up now, not communicating with the dash display. Just hopin that it may be linked to the box and changing the plug may solve it. Only had problems since the flood of water i,ve had.
    Thanks to those who have put me in the right direction. Phil
    Mar 2010
    9
    Got a replacement plug 12. Took about half an hour snipping and soldering. Cured the problem. To stop it happening again ave shrinked wrapped the the CCM box.
    Thats it done. Phil
