Faulty LCD VDO display
sherry
Hi.
My LCD VDO display has lots of dead pixels and i was wondering if anyone knows where i can get a replacement. I am able to re-solder it myself. I am finding it hard to source one of these.
Any help would be great.
Thank you.
I take it you are on about the MMI display in the middle of your dash? If so, you might as well get another one off ebay, the dealer will charge you a fortune, and it only takes 10 minutes to change
Thank you for the reply.
It is the display that is behind the steering wheel. It is in the same display as the clocks.
Keep an eye on ebay for some clocks, pretty sure the A4 uses the same DIS as the A6.
I got myself a spare set of clocks cheaply in case any of my pixels should decide to fail.
