JMB RetrofitsVolks Autos
    Nov 2007
    Ayrshire
    21
    Rear number plate lights
    Help please, bought a set of LED bulbs from ebay, went to fit them and they did not work, fitted the originals and now they don't work, DIS error now showing, and cannot find a specific fuse. Has anyone else had the same problem?
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    Turn the ignition off for about 30 minutes and see if the fault goes away, if it does not then, you will need to clear the fault codes with VCDS
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    Nov 2007
    Ayrshire
    21
    Cheers CB, been off all night and still not cleared, I'm more worried at getting the lights working again, is it as simple as new bulbs?
    Nov 2007
    485
    If your old bulbs worked, then fitting new ones wont make any difference. Chances are you need to have all the fault codes cleared which should sort out all the issues
    Q7 S Line 2010
    MMI 3G
    Superchip Remap
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    clear codes or diconnect battery for a quick solution
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    JimC64's Avatar
    Apr 2009
    Glasgow UK
    242
    Hey there Charlie, don't know about your specific problem except that I fitted LED bulbs to the number plates and they wouldn't work without fitting a resistor. Kept on getting the DIS error showing. I fitted the rersistors and they've been working fine for around 6 months at least I'd say. They look top notch and give off a really bright white bluish tinge to the rear of the vehicle.
    Please see my thread below
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=68951
    Hope it helps some
    Jim
    MY2008 (58) XJ X358 2.7 Tdvi Sovereign LWB remapped to 245bhp, Black, Ivory leather interior with black piping, 20" Alloys
    MY2007 Audi A6 2.0 Tdi SE
    176bhp Stratos Blue, badged as 3.0 Tdi Quattro.Front & Rear park assist,Comms Pack High,Sline grille badge added, 19" RS4 alloys,Rear tints,Dipped bulbs 80W,Mainbeams & Foglights 100W,Number plate LED's,Interior LED's,First Aid Kit,Bootliner,Mudflaps front & rear,Calipers & hubs painted
