Volks AutosAH Fabrications
    Mar 2010
    7
    Question A6 1.9 TDI engine management problem?
    Hi, car is an 02 A6 avant with the 1.9tdi ( 130bhp )
    high ish miles 128k.
    Been running fine ( if a little smokey/exhaust smell at start up ) - nasty feeling I may have snagged the exhaust on a metal parking bollard that was laid flat ).
    Started fine yesterday, drove 5 -10mins, parked up.
    Went to restart hour or so later - no start, ignition fired up, engine starts - then dies immediately.
    tried dabbing throttle - no response.
    tried restarting - same problem again.
    Engine management warning light has come on.
    Any thoughts on what this might be?
    Might be something a local independant can deal with.....local main dealer has been caught with pants down specifying huge amounst of unnecessary work - so much prefer not to go near them!
    Thanks for any pointers,
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    You may have damaged the Lambda sensor which measures the O2.
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    Not on a Tdi he hasnt, no 02 sensors!
    You really need to pull the codes from the car to see whats going on! Any local garage should be able to do this for you, you can even buy VAG code readers for like 20 now!
    I cant imagine it been anything serious, where abouts are you as i have full diag tools for every car going?
    Chris
    Mar 2010
    7
    Hi - thansk for comments.
    Chris - any suggestions on which Diag tools fit a 2002 Audi ( OBD2? ) as think for 20 might as well get one, we're in Oxford.
    Afraid im in Sunderland!
    But, for example, something like this will do the job, will read and erase codes, http://cgi.ebay.co.uk/OBD2-VW-Audi-S...item3ef93367cd
    Fox
    Oct 2007
    41
    I can probably help you out if you are anywhere near banbury?
