Badger5Sky Insurance
Results 1 to 7 of 7
    Apr 2009
    42
    Ignition Playing Up
    Help / Advice needed,
    Have got an audi a6 avant 1999, about a year ago i had a problem with the ignition code, when i went to start the car the light flashed to say it didn't accept the key. I eventually changed the barrel and reader. It was working fine until we had all the rain the last few days. It has flashed up a couple of times now.
    Has anybody had this fault?? any advice would be great.
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    not sure, maybe check your footwell carpets for wetness as your ecu sits under there......
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    Apr 2009
    42
    Yes i thought of that, the carpets seem to be ok. I have taken the cover of for the ecu and that seems all dry under there as well. It always seems to be when it rains / driving on wet roads.
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    get vag com on it see what faults its kicking out.....
    Apr 2009
    42
    I have already got a copy. All it gives me is a fault saying start blocked by immobiliser. There is no other fault, which doesn't help matters
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    have u got another keyfob to use, just in case that is the problem?
    Apr 2009
    42
    Yes, i did try it last time. Might have to try it again,
