Volks AutosBadger5
    11
    2.5 TDI started smoking since service.
    I changed the oil, oil filter and air filter yesterday, it seemed fine at the time and afterwards but now smoke with a blue tinge (burnt oil) is coming from the exhaust, not loads but it wasnt there yesterday.
    Is this somewhat normal after an oil change on a high mileage diesel or is it something else?
    I appreciate that it could be something devastatingly bad but is there any smaller, cheaper things worth checking first?
    Just had a search, seems maybe the EGR valve should be cleaned out, but this doesnt really solve the problem of why it has started just after a service.
    Many thanks
    Ant
    Aug 2009
    34
    Hi Ant1989
    To see if your EGR valve is blocked remove your oil filler cap & listen for a 'pop' of pressure being released. I had the problem & it seemed to come on all of a sudden & perhaps the oil change is coincidental.
    John C.
    11
    Thanks,should the car be running or not when I remove the cap.?
    It actually seems to have settled down a bit I don't know if I might have slightly overfilled it, it was maybe 1mm over the max mark. I've done that with a lot of cars with no consequence, are the tdis very sensitive to overfilling?
