AH FabricationsChris Nott
    Sep 2009
    25
    Changing Rear Brake Pads 2006 A6..........
    Is there a twist with these? Just asking as it has an electronic handbrake.
    Do you need special tooling?
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    I don't know about the A6 but on the passats you need to use VCDS to do something, it might be the same?
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    Changing the pads on an A6 with electronic handbrake, requires VCDS
    Open Rear Parking Brake
    Prerequisites:
    • Connect a battery charger.
    • Cycle the Parking Brake ON, then OFF first.
    [Select]
    [53 - Parking Brake]
    [Basic Settings - 04]
    Group 007
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The brake calipers will then open, allowing the pads to be changed.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    It is normal for the LED in the parking brake switch and the warning lamp in the instrument cluster to blink rapidly at this point.
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
