Volks AutosEM Tuning
    12
    Retro-fit Sat Nav Up-Grade.
    Does anyone know how complex it would be to fit an Audi RNS-D Sat Nav into my 2004 A6?
    I see them for sale and quite fancy up-grading the existing equipment and was wondering whether it's as simple as plug and play and whether additional kit is required?
    Any advice/experiences would be gratefully received.
    Cheers,
    Ace
    TDI
    Dec 2007
    Bracknell, Berks
    64
    If you have Symphony system it will be almost p&p but if you have single DIN radio it will cost you some and work.
    Professional chiptuning (most makes and models) and diagnostics (VAG, BMW, Vauxhall).
    12
    Many thanks, I'll do some more home work and planning.
    239
    changing the dash bracket from a single to double is gonna be the hardest job, to do a 'factory' install your need a new bracket, new climate control unit and ashtray plus other odd bits.
    apparently the existing climate unit can be modified to fit, so that would save a lot, but i would guess at nearly 200 for the bracket and bits.
    Have a look on Google has all been done before,
    not much info on this link but the pictures give you an idea of what you need to do
    http://www.mp3car.com/vbulletin/lcd-...a6-1999-a.html
    http://audiforum.us/rns-e/938-rns-e-...lroad-rs6.html
    239
    double din rack - 4B0 858 005 K 01C
    ashtray - cover - 4B0 857 967 H 6DP
    a/c module - 4B0 820 043 C B98
