Volks AutosJMB Retrofits
    Oct 2009
    Preston
    88
    A6 Avant quattro rear discs question
    I've a 2003 2.5 TDi Avant quattro and the rear discs are due for replacement, so looking at after market Brembo site I see there were 245mm and 255mm diameter discs for this model - this explains the rust on the outside edge of current discs, which are 255mm but should be 245mm.
    Anyone know which models the 255mm were fitted to and if its only the caliper carrier which needs changing to use 255mm discs - I know its only 10mm but if its dead easy why not?
    TDI
    Dec 2007
    Bracknell, Berks
    64
    Send VIN so we can check what discs you should use.
    Professional chiptuning (most makes and models) and diagnostics (VAG, BMW, Vauxhall).
