EM TuningAH Fabrications
    Apr 2007
    cheshire
    34
    Power steering moan and rumble
    My steering has started moaning and vibrating, especially when the car idling. This gets worse when steering at slow speeds and stopped. It's also started to loose fluid (it's always lost a bit, but it's now worse) and once when I checked straight after a run the fluid was full of air bubbles. Is the steering pump on its way home? Anyone had experience of changing one of these? Does the whole front of the car have to come off like it has to for so many other jobs?
    Thanks.
    1999 Audi A6 Avant 2.4 SE Tiptronic
    1965 Rover 3 Litre Coupe manual o/d.
    TDI
    Dec 2007
    Bracknell, Berks
    64
    Most probably pump or steering gear is dying.
    Simply check where you have leaks and change component. Pump is easy to replace yourself while steering gear it real pain in the neck.
    Professional chiptuning (most makes and models) and diagnostics (VAG, BMW, Vauxhall).
