EM TuningSky Insurance
    Mar 2007
    salford gtr manchester
    564
    Brake pad warning symbol
    hi all i have got a strange problem with my car this week the brake pad warning symbol is on the display the funny thing is it only lights up when i put the car in reverse gear the pads are virtually new and it does not light up when driving forward but the second i select reverse it lights up does anybody know the link between the warning light and reverse gear ?
    meatychi's Avatar
    Jan 2005
    UK
    260
    it might be just a dodgy contact!
    1998 A6 Avant 2.5tdi Quattro Tiptronic Sport
    Mar 2007
    564
    thats what i was thinking but why only when i select reverse does the warning come up
    Aug 2009
    Norwich
    20
    A couple of things . . . . is the car auto trans? If so, when you select reverse, the wheel may rotate sufficiently to move the pads a mm in the caliper and perhaps a chaffed wear indicator wire is earthing out ???
    The other point is a million to one, but worth a thought. Does the handbrake warning wiring share the same light? The wiring from the handbrake switch will probably run forward and may have been chaffed by the gear selector lever and then shorting out as you select reverse. As I say, a chance in a million but possible.
