Monster MotorsportVolks Autos
Thread: ABS light on
    Apr 2008
    171
    ABS light on
    Hi.
    I have the warning light saying there is a problem with my ABS. I have checked my fluid level and this is ok.
    Would anyone have an idea on what to check next?
    cheers
    May 2009
    Tonbridge
    14
    When i had this warning i thought it was going to be the ABS control module, but it ended up being the steering angle sensor (260 part to replace and 30 mins to fit).
    Basically i needed to go to a garage with a VAG reader to let me know what fault codes had been recorded. Good luck
    Audi 4.2 Quattro v8 Tiptronic
    Silver, no mods (Yet)
    Apr 2008
    171
    thank you m8.
    i will look into it
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Need a vag-com to plug in mate, that'll tel you firstly if you can access the ABS Control module (if not it will need remanufacuring at approx 100) if you can get it it'll throw up some fault codes to check, usually a wheel speed sensor or something.
    Oh and don't go doing any heavy braking as you won't have ABS if the light is on, it's a visual alert to tell you something is worng and so the ABS cannot function properly.
    Apr 2008
    171
    thanks for the reply m8. i have already got a cheap cable that i bought for my last a4. i will have a go with that and see what it brings up.
