EM TuningAH Fabrications
Results 1 to 7 of 7
    Oct 2009
    Whats your water temp?
    Hi guys,
    Recently brought an A6 Avant 2.5tdi Quattro 2001. Noticed that when driving along motorsways etc the water temperature barely goes above 60, however went i sit in traffic the temperature goes between 70 - 80.
    My Passat always used to be at 90, either when driving along motorways etc or if sitting in traffic.
    Does something seem wrong? What can i do to check / solve this?
    Thanks for your help.
    Duke
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    Yeah mine used to do that but since i had the water pump replaced and the temperature sensor replaced its now back to 90. Almost certainly an electrical problem, just need to work your way around sensors and wiring. Theres a thread on VWaudi forum i read recently about this problem, you should be able to search it out fairly easily.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Oct 2009
    Do you think it might be something to do with the thermastat?
    Another thing, is it safe to drive? Been driving around the past couple of weeks with no apparent problems!
    Feb 2008
    55
    Its not per se dangerous, but you should get it sorted asap as the faulty sensor (very likely cause) causes the computer to act differently with fuelling etc. Happened to my A4 and i just followed instructions on a thread and replaced it - problem solved.
    Of course, it could be other things but you need to diagnose it based on the info in the threads. There are two main temp sensors from memory - it could be either or neither. Best of luck.
    Mar 2007
    salford gtr manchester
    564
    does it take a long time before your temp gauge starts to move if so that sounds like your thermostat mine was exactly the same until i replaced the thermostat now its up to 90c in a couple of miles and sits rock solid at that temp when i removed the old one it was not stuck open as i expected i think it was just opening far too early my car is a 2.8 v6 petrol but the symptoms are the same
    Aug 2009
    Norwich
    20
    Very likely to be the thermostat. Certainly not dangerous if it is the stat. The main downside will be the extra fuel going in unneccessarily. The ECM will think the engine is still warming up and will apply "a bit of choke" . . . . enrichening. All this is exactly as Silverstealth said earlier, just adding my two penneth! Changing the stat can be a bit of a job timewise on the A6 2.8 V6, not sure on the TDi engine, but worth doing as we are coming to the winter months. The colder the outside temps, the lower the engine temp with a dodgy stat . . . . lower mpg.
    Dec 2007
    Winchester, Hampshire
    36
    I agree with yendall24 & Bobtech, mainly because I had exactly the same experience as yendall24. Bear in mind also that your engine oil won't be getting fully up to temperature, which is never a good thing.
