Badger5JMB Retrofits
Results 1 to 13 of 13
    S6 LeMans's Avatar
    S6 LeMans Man
    Aug 2009
    Warwickshire
    27
    Question Engine Start Button Upgrade
    Has anyone got any idea if it would be possible to change the old square plastic button to the new 09 model Chrome version?
    As you can see from the pictures below - the original housing/surround is still the same in the new 09 model year centre section. So I guess all that would be required from a dealer is a new housing and button - plus whatever time is involved in removing/accessing the console.
    Current version
    New version [ left hand drive though ] + CHROME ENGINE START
    Close up of button and its housing/surround
    I also like the neat chrome touch to the park brake.
    If you can easily change the panel = great
    I'm in at the dealers tomorrow - i will ask and report back
    S6 Stuff
    TV + Reverse Camera
    ipod & iphone
    All the "PACKS"
    Heated Memory Seats Driv & Pass
    Power Close Doors
    Exclusive Interior - Black/Silver
    Auto Foldaway Towbar
    Privacy Glass
    Advance Key - Keyless Go
    RS6 Xenons + DRL's
    More extras than a Hollywood epic
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    I would say it would be fairly easy to do, as the footprint is the same, however, it is just a button or is there some logic involved. You may want to ask a8tech (forum member) the question.
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    Aug 2009
    200
    Seems doable with minimla effort. See this link
    http://forums.audiworld.com/showthread.php?t=2756260
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    S6 LeMans's Avatar
    S6 LeMans Man
    Aug 2009
    Warwickshire
    27
    Dropped my car in for some work today at the dealers - I had emailed them this question & they think its as easy as swapping it over?? The part is 30 - but is on back order. But to make doublely sure - they are checking if theres no other software change required??
    I have told them once that's established - then order me one ASAP
    They did say that when the change took place on the A8 - that was no problem - but the A6 they have no experience as yet.
    S6 Stuff
    TV + Reverse Camera
    ipod & iphone
    All the "PACKS"
    Power Close Doors
    Privacy Glass
    RS6 Xenons + DRL's
    S6 LeMans's Avatar
    S6 LeMans Man
    Aug 2009
    Warwickshire
    27
    Quote Originally Posted by elan2s View Post
    Thanks for the link - it confirms can be done
    But for those wanting to know imm. Here is how
    Audi A6 C6 Engine start/stop button removal and installation:
    Materials: Plastic spatula (anything that will not scratch), paper towel
    Remove the leather boot around the gear selector using the spatula wrapped in the paper towel (to avoid scratching). There are four tabs, as shown below. Start by inserting the spatula on the passenger side of the boot.
    With the boot out of the way, remove the gear selection indicator by applying upward pressure from underneath
    Now the start/stop button can be removed by using your fingers to push it up and out.
    8 pin--direct replacement
    After
    Its a nice easy mod for something you will see every time you get in. There is a similarly facelifted parking brake switch available.
    S6 Stuff
    TV + Reverse Camera
    ipod & iphone
    All the "PACKS"
    Power Close Doors
    Privacy Glass
    RS6 Xenons + DRL's
    Nov 2007
    485
    That looks very easy.
    Q7 S Line 2010
    MMI 3G
    Superchip Remap
    S6 LeMans's Avatar
    S6 LeMans Man
    Aug 2009
    Warwickshire
    27
    It's even easier than that........... I managed to pull/lift out the entire housing for the stop/start buttons just by using my fingernails - its that easy - they are not held in tightly at all - there is just a small spring bar retainer clip at each end.
    S6 Stuff
    TV + Reverse Camera
    ipod & iphone
    All the "PACKS"
    Power Close Doors
    Privacy Glass
    RS6 Xenons + DRL's
    Nov 2007
    485
    Quote Originally Posted by S6 LeMans View Post
    Yo must have fingernails like a Gorilla, there is no way im chipping my nail polish to do that mod LOL
    Q7 S Line 2010
    MMI 3G
    Superchip Remap
    S6 LeMans's Avatar
    S6 LeMans Man
    Aug 2009
    Warwickshire
    27
    Thumbs up
    It was even easier than previously described:-
    Fitted the new push-button switch in less than a minute last night.
    Simply use a credit card edge [ or similar ] to slot into the gap/surround of the original switch to assist in uplifting the switch assembly proud of the console. . . . . . then easily pulled proud with enough spare cable behind it. The switch is connected with a simple to remove/replace single cable.
    Attatch the new switch - replace in console = Job Done
    Total cost = 34
    S6 Stuff
    TV + Reverse Camera
    ipod & iphone
    All the "PACKS"
    Power Close Doors
    Privacy Glass
    RS6 Xenons + DRL's
    Nov 2007
    485
    Like Paul Whitehouse says in the Aviva ad, "Bargin"
    Q7 S Line 2010
    MMI 3G
    Superchip Remap
    Golfather's Avatar
    Mar 2003
    Slough
    25
    Total cost = 34
    All you need to do now is upgrade your steering wheel and your dash trim
    Hi! i am trying to do this but my dealer has got the wrong switch.
    Does anyone have the RHD UK part number, i have only found a US lHD one?
    I found it and thought I would post it for info.
    It is 4F2 905 217E VUV.
    It cost 38 inc the VAT and easy to fit.
    I used a small watch screwdriver inserted into the switch (ignition key left in the house just in case) and it just opped out with just gentle pressure. Looks great!
