    S6 LeMans's Avatar
    S6 LeMans Man
    Aug 2009
    Warwickshire
    27
    Question Flat Bottom Steering Wheel - A6?
    Has anyone fitted a flat bottom multi function steering wheel to their A6?
    I have been watching them for sale on ebay of all places recently - and a specialist aftermarket seller, however my dealer seams to think that in no way will they be compatible? I'm just not sure??
    see ebay item number 220470553672
    Its obviously from a TT - but the description says it will fit an A6
    It just the job for me if it does - ir MFSW controls - Paddle shift & has the silver stitching to match my interior.
    Another company selling this conversion is http://www.vwcruise.com/46.html
    S6 Stuff
    TV + Reverse Camera
    ipod & iphone
    All the "PACKS"
    Heated Memory Seats Driv & Pass
    Power Close Doors
    Exclusive Interior - Black/Silver
    Auto Foldaway Towbar
    Privacy Glass
    Advance Key - Keyless Go
    RS6 Xenons + DRL's
    More extras than a Hollywood epic
    Golfather's Avatar
    Mar 2003
    Slough
    25
    The TT ones are not plug and play on the A6.
    But I managed to fit mine successfully after a bit of investigation
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Before you fit one, maybe you should take a look at this thread on TSN...
    And regardless of what anyone says, there is no proof that this mod works in the real world.
    http://www.tyresmoke.net/forum/audi-...irbag-pic.html
    Golfather's Avatar
    Mar 2003
    Slough
    25
    Yes seen that thread before.
    It certainly does bring home the fact that any sort of modding over and above OEM can have severe consequences as it can never be tested to the same level as manufacturers.
    However in this instance, we are fitting a dual stage airbag to a dual stage controller unlike that in the thread so there is more confidence that it should work. Indeed, the C6 RS6 uses the same design of wheel and airbag from factory, with the same airbag controller common to the A6 range, further strengthening this theory.
    The proof will be in the pudding...
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Ok, yes sorry, I agree C6 is fine, in fact I have one on my C6. It works well with slight modification to the original harness to fit it to the TT wheel.
    Jan 2014
    Did you fit this in the end?
    Hi
    did you manage to put the steering wheel in? I am thinking of doing the same, I also have a6 c6 2007 se spec, with paddle shift, any advice on any other steering wheels, which I have seen on eBay?
    Quote Originally Posted by S6 LeMans View Post
    A
    Hi
    Another company selling this conversion is Vw Mk4 Golf Cruise Control - Vw & Audi Sat Nav, Bluetooth , TV Tuners, Cruise Control Installations UK
