Hi all...had a few problems with my 07 A6 2.0 tid which have included cold / non start issues and loosing coolant among them.
Having taken advice I've visited the dealer many times re the low coolant issue and they've replaced the cylinderhead around a month ago. Since that time I've experienced an oil leak that wasn't there before and the engine hesitation as mentioned......usually in lower gears 1st through to 3rd, sometimes 4th and around the 2000rpm mark, there's a slight flutter / hesitation in picking up, more noticeable at low speeds.
Took it back to the dealer and complained - They've since fitted another new cylinder head as the cam shaft was out of spec and caused a problem with a seal seemingly.
Car was in for around 8 days or so for this to be done and I wasn't best pleased to say the least.
The issue now???
Since I've had the car back Friday I think it was I've suffered with the same engine hesitation - something is definitely NOT RIGHT.
The other issue is that on Sat am and early today on first start up the car wil not fire......almost like water in the fuel or low battery where it just turns n turns and eventually catches
I'm gonna be on the phone to them tomorrow and see where we go from here.....I was hoping that anyone tech mided / with knowledge may chime in with any thoughts or ideas??
Jim
