Sky InsuranceVolks Autos
    Jun 2009
    Lincolnshire uk
    Various faults A6 C5 AKE Quattro Sport Trip 2001
    Hello all, I would be greatfull for any feed back on the following problems:
    1. Blebs in paintwork, on all 4 wheel arches, door bottoms and edge insert strip of roof and bottom of boot door window.
    2. On uneven bumpy roads, its all over the place, sometimes the rear end skips out on pot holes. The only thing I found is the front lower track arm bushes have slight movement (same both sides) is this normal.
    3. Drivers door catch switch does not put on the footwell door and int lights.
    4. LCD display is fading.
    5. Camshafts are noisy. Could they fail.
    Car done 178,000 miles full Audi service history
    6. Sometimes the autobox seems a little lazy hanging on to the gears when gently accelarating. Is this common?
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    I have no paintwork problems other than a couple of chips
    The bushes will wear out, this is common to most Audi models, mine were noted as showing wear at the front at the last service (193k). The rear alignment is adjustable on these quattros, unles you and your previous owners have been aware of this it could be well out, mine was when it first got sorted at about 120k. Also when was the last time the shocks were replaced?
    Drivers door and LCD display do not have problem
    Your car is likely to suffer camshaft failure, and all the followers too. Get them checked before something more serious happens. Been there have t shirt. Long life service intervals and low speed running exacerbate the problem
    Mines a manual can't help with the auto
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
