AH FabricationsChris Nott
    May 2009
    Hi, gearbox judder when pulling away in my auto avant??
    Hi, I've come back to Audi after a 10 year gap (used to have a 1990 90 2.3e) and i've bought a 54 A6 Avant 1.9tdi auto.
    I love the car but when i pull away at a steady pace there's a slight judder which i presume is gearbox related, like a slight kangerooing you'd get from letting the clutch out too quick on a manual gearbox.
    If you i put my foot down and pull away fast it doesn't seem to happen.
    Any help or suggestions please as the cars still under warranty.
    thanks
    Simon
    Mindrunner's Avatar
    Big Nuts Massive Spanners
    Jan 2009
    Teesside
    36
    Hi,I had the same problem with my A6 2.7 1999 Manual, I had the clutch and flywheel changed and replaced the rear g/box mount which had snapped. I would check the rear mount first if thats fine then it will prob be flywheel judder.
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Is it a multitronic auto? If so, these gearboxes can be troublesome. They need oil changes every 40,000 miles so check to make sure it's been properly looked after.
    Do a search on here for CVT or multitronic and you'll find more info...
