Driver's side map reading light
amimmortal
Dunfermline
Well, as far as I can see, the only thing amiss with my new A6 is a faulty reading light on the driver's side.
Can anyone give me an idea how to replace the bulb, and where I might find one?
Thanks!
A.
Get your finger nails under the front edge (nearest the w/screen) of the whole unit & ease it out of the headlining. Unplug the connector & take out the three scews & remove the cover plate. There is a small stop plate at the end of the bulb. Swing this up out of the way. Twist the bulb & remove it towards the centre of the unit. You can get the bulbs from the Stealer, Halfords etc. They are 12volt, 5 watt. (This applies to the C5 A6 without sunroof, might be slightly different with a s/roof & don't know if C6 is the same).
HTH
Dave
Thanks Dave...
Sounds like a bit of a rigmarole...
I'll give it a try but I'm paranoid I'll make an **** of it!
Cheers,
A.
