    Dec 2008
    a6 1.8t se quattro 2002
    hi there
    i just got the engine management light on all the time in my car.
    what that mean?what should i do?
    i am a bit worry about that
    any one can help??
    regards
    mo gharib
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    you need to get it checked,
    your options are
    1. at a dealer
    2. at a garage
    3. someone with vagcom
    4. you get vagcom and a lead,
    read the code and find out whats up!
    Matt
    Dec 2008
    hi there
    yeah i took it for check today and they said its exhaust convert rattling.
    and needs replacing but he cleared the codes for me and i have not got that warning againg?how much do you think will cost?is it safe to drive now.?
    thanks
    regards
    mo gharib
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    yeah should be fine, the engine management light will be telling you there is a fault, your car will have a lambda probe before and after the cat.
    if the cat has failed - the rattling - the second probe will detect that it is not doing its job properly and will throw a code.
    the second probe will not affect the mixture or the running of the car, it is there to check the cat is working correctly.
    the cat will need to be changed, depending on how bad it is the core could move and partially block the exhaust, or it may just shake its self to pieces.
    you will need to get it changed before an MOT as it should not pass!
    Matt
