AH FabricationsVolks Autos
    Dec 2008
    ESR and ABS lights on
    Guy's can anybody help. My ESR and ABS lights came on tested both and they don't work then yesterday my Glowplug light started flashing on my A6 1.9TDI auto. No brake lights work, she has done 96,000 but runs fine apart from the lights. The glow plug light comes on when the engine is started and the ESR and ABS comes on when in gear and foot off the brake. Thanks Steve
    enda1's Avatar
    Jan 2006
    Ireland
    439
    I think the brake light switch on the foot pedal can cause alot of these problems. It very cheap and easy to replace. Try this and it might sort it. Otherwise find someone with vagcom to scan the fault codes for you
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    simonwjones's Avatar
    Aug 2005
    staffs uk
    344
    Its definately the brake light switch, had the axact same symptoms on my old car
    Its a cheap and easy fix
    cheers
    Simon
    A6 2.5tdi Quattro Sport 180
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    RNS-E, Audi BT, Phatnoise
    41
    same here. a new brake pedal switch sorted it out
    Oct 2005
    UK
    14
    I've also had this problem. See my other post.
    ABS and ESP lights - Brake pressure sensor fault - Help!
    I was getting error Brake Pressure Sensor 1 G201 01435
    There are very helpful instructions on fitting a VW brake switch on
    http://forums.vwvortex.com/zerothread?id=1158315
    When you twist the brake pedal switch during installation that locks the switch piston length. It is important to install it so that the rear brake lights come on with the minimum brake pedal movement. I think I had the problem because there was quite a bit of movement in the pedal before the rear lights came on. It's worth fiddling with the switch, it's cheaper than an ABS pump!
