JMB RetrofitsBadger5
Results 1 to 15 of 15
Thread: cv joint
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    cv joint
    i got a loud noise coming from the drivers side wheel i took it to a garage and the mechanic without evening looking at it said its the cv joint common fault how much am i looking at this repair ?
    200 Horses nice !!!
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    iirc the kit is about 50 per joint, i maybe wrong, and then u got gearbox oil (as whole shaft has to come out). Then possible 3 hours labour @ 30 for the cheapest 80+/hr for stealers
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    took it to another garage today and found out that the cv boot had come off so there was no grease in the joint, thing is its a new cv boot that i had replaced about six months ago from another garage
    200 Horses nice !!!
    Dec 2004
    Bristol
    449
    Yeah they do split easily, another common fault.
    Fixed one of mine (for the second time now) with a cheap stretchy universal boot, it's not the proper one but has been on a year and will see how it lasts.
    When we realised we had to completly remove the shaft and split it to bits just to do the boot we opted for the cheap one to pass the mot.
    It's much stretchier so may last longer, will see, only time will telll i suppose.
    Dec 2007
    Winchester, Hampshire
    36
    Assuming its a front outer joint (the most common to split it's boot & fail) the driveshaft does not have to be removed. The joint can be pulled off & replaced with the shaft in situ. I did mine in september for a total cost of 39.45 (31.14 for the joint kit from Euro car parts - includes everything you need but the clamp bands really need a special tool so I used large Tyraps - & I chose not to use the axle bolt supplied with the kit & bought a new genuine bolt from the Audi stealer which was 8.31). If you're going to tackle the job yourself, try this article http://audi.kris-hansen.com/cvboot.htm . You will also ned a pretty reasonable tool kit. If you're going to get the job done by a garage I suggest you buy the part yourself & ask a good Audi independant to fit it. I'd agree with Evo at three hours labour but that should be maximum. Maybe worth going back to the original garage that did the boot & see what they might do about it.
    HTH
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    well found out today i had the cv boot replaced on 19/11/07 so im not gunna be able to take it back to the original garage and complain
    looking at the link you provided it would seem i need a bearing puller which i aint got
    things just go from bad to worse!!!!
    200 Horses nice !!!
    please speak slowly so i'll understand !
    Nov 2007
    north of the border
    160
    hi mate you dont need a puller at all ! takes 25 minutes piece of piss job just take your time and be prepared to get very mucky !!
    Dec 2004
    Bristol
    449
    That link is very useful wish i had it when i did mine.
    Think it should be made a sticky on a common problems page how to fix jobby.
    Dec 2007
    36
    I tell you what bigdavie, if you can find me a garage that would charge half an hour labour for doing a C.V. joint, then I'm a Scotsman (I'm a born & bred Southerner!) & I'd happily pay them the money to do it.
    Dave
    Nov 2007
    north of the border
    160
    Quote Originally Posted by DGSdale View Post
    Dave
    lol mate i'm a time served nissan / fiat mechanic (many moons ago right enough ! )
    and the longest part of the job is jacking up /securing and removing the roadwheel !!
    honestly its a doddle ! air tools do help though !!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    well im not used to getting dirty these days so i might ask a m8 to do it for me thanks for the help guys
    200 Horses nice !!!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    Quote Originally Posted by bigdavie View Post
    so what do i use instead of a puller ?
    200 Horses nice !!!
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    had it been fitted with a proper band to hold gaiter in place or crappy zip-tie...cuz ive seen that done before....
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    they seem to use zip ties for some reason bloody rubbish however i got it sorted in the end i got a local mechanic to do it for 30
    200 Horses nice !!!
    Dec 2007
    36
    Discovered a while ago that the CV boot clips are available separately from the Stealers (just over two quid for the large one) so I swapped my cable ties out.
