Volks AutosMonster Motorsport
Thread: A6 Cambelt
    Oct 2008
    42
    A6 Cambelt
    Hi I am new to this forum and was after some info, I have a 2004 3.0tdi quattro A6 (4F) just the start of the newer shape.
    My question is does it need a cam belt change, if so when should it have been done.
    If it does need one, is it worth doing water pump at same time?
    Any recommendations on a good indie for the job in Birmingham / West Mids area?
    Many thnaks
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    50k for a diesel cambelt without knowing when it was done and if its over then id consider getting it done.
    Youll need a water pump and idlers done as well .as before look at the thermostat and coolant temp sensor. as youll have to remove the cambelt to get to the waterpump anyway and the others need the system drained or partially drained anyway
    Water pump about 25
    thermostat around 10
    Coolant temp sensor 16
    no ideas on an indie
    Water pump will go anyway and can take the cambelt with it. its not worth scrimping on this as they have a useful life of around 80K or so.
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
