EM TuningSky Insurance
Thread: hunting
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    hunting
    my audi a6 1.8 t is hunting in idle when first turned on any ideas it does settle down after a while but still it shouldnt be doing it
    200 Horses nice !!!
    Aug 2008
    13
    Remove and clean the throttle body as it will be badly coked. Alos if fitted check the vacuum pipes to the secondary air valve as it can split.
    Aug 2008
    Kidderminster
    22
    New to the world of Audi, but had similar problem on my Honda that was caused by a dodgy intake temperature sensor (I'm assuming Audis have them too ). Cleaning didn't work, but replacing with a good one solved completely
    HTH
    Let there be light, sound, drums, guitar
    LET THERE BE ROCK
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    intake temp sensor has been mentioned b4 but ive not a clue where its located
    200 Horses nice !!!
    Aug 2008
    13
    Its built into the air mass meter but do the other checks I suggested and it should be better.
