Monster MotorsportEM Tuning
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Problems with remote locking/alarm, help
    I've had a couple of gremlins creep in to my car! Or at least thats the only way to describe it!
    Got a few problems with the locking system as when i unlock/lock the car sometimes the car then locks and unlocks itself a few times and sometimes the windows go down aswell but sometimes not uniformly they will stop n start also the interior lights with light up then dim and light up.
    This can happen when driving too but the window problem doesn't happen, but locking/unlock and interior lights comming on can happen.
    Then after the system has done it's tricks the remote locking won't work atall. but the alarm will as i can see the led on the doors light up when i press the remote.
    I'm baffled, i've got a new set of batteries for the remote as i've had the car 4 years so they could be on their way out, only other thing i can think of is water in the central locking modules as i know similar problems with ford galaxies due to water in the central locking/alarm module.
    Anyone know where the central locking/alarm control module is located on a 1998 A6?
    Any info/help much appriceated
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    water
    have you checked under the passenger carpet. sounds like water under the carpet and got into the ECU.
    A6 2.4Se Man
    Bmw 520Ise Auto
    Dec 2004
    Bristol
    449
    Will do many thanks, will let u know how i get on, didn't know where the ECU and stuff is stored on these, i'm a bodywork type, well with this car anyway
    Dec 2004
    Bristol
    449
    Thanks for the info, just ripped out the seat and the carpet and it's soaked.
    Must be the issue, now drying it out, i think i sourced the cause, i had the windscreen replaced recently and he hadn't fixed the bottom trim on properly so i think water was leaking throught the interior fan and in to the foot well.
    Thanks for the advise, hopefully this will sort it.
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    Evo
    Check the drain holes also in the front bulkhead where the battery is you will need to remove the battery here to access them. but is more than like ly blocked causing your problem.
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
