Badger5JMB Retrofits
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    cant open rear door
    hi all i dont post on this platform as i have a b5 A4, however my brother has a 1999 A6 and he cannot open the OSR door either from inside or outside if he tries and open the handle from the inside the little knob pops up but still cant open..
    i think we would need to take the door card off can this be done with the door closed?
    any ideas
    cheers
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Try messing around with the key in the ignition and disconnect the battery, lock and unlock the car using the key and the button inside that car, i had the same problem with the front door on mine and fixed it somehow messing with the unlock button inside.
    Aug 2008
    13
    You'll find that the deadlock is stuck which is part of the lock mechanism/catch. Stand next to the car and give the door a good bang on the area where the latch unit is and at the same time operate the remote fob quickly locking and unlocking. [Check the other side as a reference point] If this doesn't get it free the panel has to come off but it will have to be destroyed. Once off a sharp knock on the mechanism should free it.
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    I got the opposite one of my rear doors wont lock
    It goes trought the motions but just does't lock or operate the footwell lights and i am dubious its working on the alarm.
    I got a lock from ebay so will fit that when it arrives hopefully thatll sort it.
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
