Sky InsuranceJMB Retrofits
Thread: Breather Pipe
    Apr 2007
    cheshire
    34
    Breather Pipe
    A6 2.4 V6. What looks like a crankcase breather pipe, that runs from the back of the engine over the top of the rocker covers to the front of the engine. This has gone brittle and fallen to bits. I understand this is a fairly common problem. Is this a dealer only part or can I get one elsewhere? Any part number?
    Many thanks.
    1999 Audi A6 Avant 2.4 SE Tiptronic
    1965 Rover 3 Litre Coupe manual o/d.
    karl7900's Avatar
    Nov 2006
    1,402
    Post up a picture if you can so we can see exactly the pipe you mean. I replaced the "Blow off" piping around the engine bay and it only cost 14 per meter from the main dealer. I've a 2.4 V6 too btw.
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    if you are asking about the black pipe which runs from the block via the throttle body at the rear and to both cam covers, that is of square section as it passes the coil pack, then yes it is a dealer part.
    or look here:
    http://www.audiworld.com/tech/eng.html - for breather hose repair in the a6 section.
    if you are talking about the small diameter round vacuum hose then you can get that anywhere.
    matt
