JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
    filipharvey's Avatar
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Unhappy Coolant Temperature Guage
    Picked my 1.8T A6 up today.
    It was fine for about 10-15 miles, and then the temperature went up to about 110 degrees. If I dropped my speed to about 40, it would then drop back down again.
    At slow speeds (road, not necessarily engine) it seems fine, but go faster and it creeps up.
    Any ideas on what it could be?
    Temp sensor?
    Thermostat?
    Water pump?
    Audi A6 1.8T Avant
    Alfa 156 3.0 V6 Veloce
    Jan 2007
    Hampshire
    1,155
    Water pump sounds possible, although the other two are common on the 1.8T.
    If its overheating though that sounds the water is not being circulated - pointing to the water pump possibly?
    A6 3.0 TDI.
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    It never goes hotter than 110 and always drops back down to 90 when I slow down.
    When the car was stationary and I turned the ignition on , the gauge showed 90 then crept up to about 105 without me even starting the engine. Turned it of and on again and it showed 90???
    I haven't had the opportunity to do this when the engine is running as of yet though.
    When stationary with the engine running, water seems to be pumping back to the expansion tank ok.
    Audi A6 1.8T Avant
    Jan 2007
    Hampshire
    1,155
    Try a temp sender first then, thats the cheapest and quickest thing to change.
    A6 3.0 TDI.
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    You don't know whereabouts that is on the 1.8T do you? Also will one from a A4 1.8 (NA) fit as I know the one from my A4 of that engine is ok?
    Audi A6 1.8T Avant
    Jan 2007
    Hampshire
    1,155
    I couldnt say for sure but I imagine they 'might' be the same.
    There is a guide on the forum smewhere for changing one (on an A3 though I think)
    A6 3.0 TDI.
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    I've looked at the back of the (NA) 1.8 engine and there are 2 sensors connected to the water pipes, I'm guessing the blue one is the one I'm after?
    Audi A6 1.8T Avant
    Jan 2007
    Hampshire
    1,155
    I think so, yes.
    A6 3.0 TDI.
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Ok, well I'll try that 1st, then the 'stat, then water pump!
    Audi A6 1.8T Avant
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Just took it out for a drive to check it.
    Was fine on the trip into town of only a few miles, crept up when nearly back home.
    I opened up the bonnet and the turbo was glowing and both fans were running. I only stopped for a few seconds and by the time I got back in the car, the temp had dropped from 110 to 90 again!!!
    Audi A6 1.8T Avant
