AH FabricationsSky Insurance
Results 1 to 9 of 9
    Mar 2007
    DORSET
    112
    Rear Window,courtesy lights & door warning PROBLEM
    Hi all .
    I have an A6 2.8 quattro avant.
    My rear passenger door (behind drivers side) has the the following problem.
    0) I have lost all electrics to the door ;
    1) The electric window , lights in the door (courtsey lights red on the side of door,white light on door sill), have stopped working.
    2) Also when the door is opened it does not display in the instrument cluster that the door is open.
    3) Also when door is opened the interior lights do not come on.
    All other doors are working perfectly.
    I have checked the footwells & they are bone dry( i have the drain holes and the plenum chamber cleaned outwice a year to prevent the ingress of water).
    If any one can help i would be MOST greatfull , cheers
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    have a look inside the rubber boot that fits between the b post and the rear door, it unclips from the post with a little levering.
    inside you will find multiplugs and wiring running from the car to the door - check the plugs are secure and clean.
    it will most likely be a broken wire at this point - the opening and closing of the door flexes the wires at this point and they can break with age.
    i had a silmilar thing occur with mine where the window did not work - checking this area i found two broken wires - repaired and has worked fine since
    matt
    Mar 2007
    DORSET
    112
    hi matt ,
    thanks for the info , i will check this at the weekend & hopefully solve the problem.
    My A6 has 129000 miles but still going strong!!
    What A6 do you have ?
    cheers
    julian
    matt_o121's Avatar
    2.8Q
    Nov 2006
    84
    mines a 2.8 quattro sport with about 143,000 on it now
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Try checking ur fuses mate if you haven't already
    Mar 2008
    42
    I have this problem, but only with the door courtesy lights (i've changed both bulbs) and the car not showing the door as open. The window still works alright. I've pulled the rubber boot off between the car and the door and the wiring seems to be OK, can it be anything else??
    Mark
    Current:
    2001 Amulet Red A4 Avant Sport 1.9 TDi
    Gone:
    2000 Goodwood Green S6 Saloon 4.2 V8 340bhp
    2000 Reflex Silver Golf 1.9 GT TDi
    Dec 2007
    UK
    22
    Hi There all,
    New to forum...I have had the same problem with my 2001 A6 Avant...The courtesy lights & warning in dash both not working (window ok).The problem is the micro switch inside the faulty door..Take the door card off,and as you look at the door from the inside of car,on the right hand side you will see the switch where all the wires go into,try wriggling them,bad connection is the cause...Hope this helps.
    rgds sjfedex (Steve)
    Mar 2008
    33
    Convinience control unit went down?
    Check all ure earths and power supplys start off with the basics.
    Mar 2008
    42
    sjfedex - i'd read that before with the switch, but people had reckoned that the switch would need replaced, that was a costlaudi only item.....i might give it a try once i've some time
    8cylinder - where is the convenience control unit, would that not affect all the other doors as well
    cheers for the replies
    mark
    Current:
    Gone:
