Volks AutosChris Nott
    Mar 2004
    Philadelphia, PA, USA
    2001 A6 2.7T -- Needs suspension updrades
    Recently bought this car and am disappointed with the body roll and fore/aft softness. Are there any warranty-safe mods that will remedy this?
    Also what ECU upgrades are available for this model after my warranty runs dry?
    Alan
    imported_hobart
    Re: 2001 A6 2.7T -- Needs suspension updrades
    If you haven't upgraded yet. I have the same vehicle and upgraded the ECU with a Giac (After much research best T& HP curve runs GREAT!) H&R coil overs(a litte choppy) and larger front and rear bars (amust)
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    or rahter $$$$$$$$$$$$$ How much this cost!
    N r the coilovers adjustable height.
    imported_hobart
    Giac chip around $800 installed and dyno'd in N. Virgina. I had to replace my worn out stock shocks anyway at 60000 miles so the H&R around $1300-1500 (US) was more than a stock replacement however, if I had to do it again I would go with 2Bennett H&R and their shock setup ($1400 US and they give good support and "know" A6 suspension). H-Sport sway bars $300 (install yourself). Web sites and good descriptions are found using Yahoo or equiv search engines. For ~$2500 a more balanced platform...next inter-cooler upgrade ($1000), A8 drilled rear brakes, etc. Guess we could go on forever
