    S2
    Nov 2006
    Alconbury, Huntingdon
    13
    Fuel filter air lock - 2.5tdi - 180
    Just done oil and fuel filter thinking a quick job. Now it won't start I have an air lock in the diesel. It's on ramps at the front so I guess this is not helping matters. Any advice on how to best bleed the air out ?? Any time now will be fine thanks !
    Dave
    Oct 2007
    25
    Did you fill new filter with diesel before fitting?Manual recommends you do so......
    '02 ALLROAD 2.5 TDI 180 TIPTRONIC
    '53 VW POLO 1.4 TDI SPORT.......62+MPG and now 215000 miles on the clock!!!!
    '98 VW GOLF TDI ESTATE.......gone but not forgotten
    S2
    Nov 2006
    13
    Thanks dj, I was a bit impatient but have a good battery! Seems the trade has problems with this at times I read somewhere. I did fill the filter with fuel. I also read to clamp the flow and return, which I didn't do. It finally started after 10 minutes of cranking, injecting diesel into the filter vent after every 15 secs of cranking. Have you replaced the filter without this drama ?
