Chris NottSky Insurance
Results 1 to 10 of 10
    Oct 2007
    Bridgwater
    13
    Quattro A6 Brakes
    Think it time i did the brakes any advise on which ones and prices.
    The rears look bad ie grooving and thin.
    The fronts have started to judder.
    I would like better feel from the pedel sometimes it doesn't feel like i am going to stop more so in the wet or cold.
    Cheers Paul
    please speak slowly so i'll understand !
    Nov 2007
    north of the border
    160
    i've been looking for some new front disks and pads myself but not having much luck finding reasonably priced ones !
    Oct 2007
    Bridgwater
    13
    Cheers dave at least some one looks at my post.
    I did get a price from my local vw dealer said about 30 pounds a disc and 70 pounds for front pads but he couldn't order them because on my quattro it's audi only even when he could see them.
    Have also heard that standard ones are the best not to touch any others like ebc or mintex.
    Nov 2007
    north of the border
    160
    30 a disc sounds reasonable to be fair but 70 a set for pads ? jeezo ! perhaps gsf may be of some use if your able to change them yourself ? http://www.gsfcarparts.com/
    karl7900's Avatar
    Nov 2006
    1,402
    Recently had my front pads changed at the last service. My mechanic has fitted Ferodo pads. I will see if I can find the receipt to see what they cost. Can't help with the discs though.
    I do know the whole service was less than what you've been quoted for pads though.
    Feb 2007
    92
    I bought a complete set of rear discs and pads through a local motor factor - whole lot cost about 70 inc VAT. I don't recall there being a problem sourcing the right ones.
    2010 A6 Avant TDI S-Line LeMans
    1999 A6 Avant 2.5 TDI Quattro - gone, not forgotten.
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    I wanted to replace my rear discs and pads last summer. Had a really wierd question as to what size disks apparently there are two sizes and the difference is the centre diameter.
    I just changed the pads in the end. Ferodos where 15 or so and took no time to fit with a caliper winding tool.
    I will change the disks next time
    I did the front disks and pads cost about 60 or so for parts all in.
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    It's worth paying for quality on brakes especiall on the front, cheap discs will warp and A6's are heavy on the fronts.
    I use Bosch/TRW very very good and affordable
    130 for S4 front discs and pads
    90 for A6 1.9tdi front discs and pads and 45 for rear discs and pads
    Dec 2007
    29
    Where can we get hold of these bosch pads then? I have the 2.7T and the pads alone are 130ish from stealers
    Jan 2007
    ayrshire
    20
    Hi my 2000 S6 rear vented disks and pads cost 106 from the dealers and the front disks were 55 each from euro car parts and pads 100 from the dealers. The euro car part disks were ate and have been on 2 years now with no problems.
